Having given up on my cr@ppy spokes-breaking Alexrim I needed to find a replacement at short notice at the weekend. My LBS had nothing suitable in stock, so I had to visit my local poncy LBS (which resides above a shop selling stuff for skiing and mountain climbing).
Anyway 100 notes later, I return home with an M:Wheel made Shimano 105 hub attached to an Open Pro rim. All well and good and a plesant hour was spent cursing whilst I swapped the rear casette and tyre, prior to fitting.
My old wheel was 130mm wide, this one looks like it's a little wider - perhaps 135mm and doesn't simply pop on - AAAGGGHH!
I don't really get it, because I was 99% sure 105 hubs only came designed for 130mm widths!
I would go back to the poncy LBS and ask, but I'm not convinced they'd be very useful / helpful, as their mechanic doesn't work weekends / evenings. I also don't feel right asking my usual LBS to sort out the mess I'm in, seeing as I didn't buy it from them.
Looking at the wheel, on the non-drive side there is what appears could be a 5mm spacer, between a locking nut and the hub. Should I simply be able to remove this (assuming I can buy a spanner thin enough to remove the nut). Or will it all end in a pile of oily bearings on the gritty floor and me in tears?
At the moment I've managed to flex the rear stays a little and get the wheel on, but this probably isn't a good solution for commuting puncture repairs!
Thanks (in advance) for any advice - Rufus.
