thanks - less confusion in future with the new series chainsets - but no triples?
I know a bit of retro step, though campagnolo re-introduced one I believe (don't know much about them though), where does it leave the likes of quality touring bikes, my set up is a 50/38/26 with a 12-27 I can change that around a lot to a 12-23 and still have the same range as a 50/34 12-30 which much better ratios, unless doing more than 3-4% hills at 90rpm I hardly go lower than a 38x24, that doesn't mean I don't use the inner 26th I do spinning up hills where I have 1th steps between the gears instead of some huge 3 and 4 th gaps.
For the record my current set has a range of 25.3-109.6" on the 12-23 it would be 29.7-109.6" then same as my 52/40/30 12-27 was apart from 4-5" at the top end, the same compact 50/34 would need a 12-30 29.8-109.6" as for weight, I haven't done the maths, but again small cogs on the rear might compensate.
Sorry if this is side tracking a little.
