John123456
Hi, I have a relatively new decathlon bike (drop handlebars), and recently a shifting problem has come up. Whenever I try shifting up on the right (i.e. towards the smallest cog on the rear cassette), my bike shifts up several gears at once, despite me only pressing the shifter trigger once. Normally it jumps around 3-4 gears, but sometimes the chain jumps right from the largest to the smallest cog with one click, which makes it very difficult to adjust suddenly when I'm out riding because it suddenly becomes very difficult to pedal. My shifting towards the larger cog on the rear cassette is fine - I know that it's normal to be able to shift a few gears down when shifting in that direction depending on how far you push the shifter lever on the handlebars. Shifting in the other direction should, however, only shift one gear per click of the shifter. I'd be grateful for any help/advice. Thanks
