nmfeb70
- Tonypandy, Wales
Hi all, so, here we go again...
My shifting has been a bit stubborn of late, the chain refuses to lift up onto some sprockets and when I slightly adjust the cable tension to shift up it won't drop back down. Despite the cable being three months old I decided to replace it along with the housing, but it still persists on giving me a headache. This morning I started from scratch, I undid the cable, manually moved the RD up & down onto every sprocket, no problem there. I washed and cleaned the cassette, chain, RD and lubricated the RD pivots, I then inserted a new, lubricated cable and indexed the shifter. What could possibly go wrong? Well, the chain refuses to play ball yet again. It doesn't even attempt to move up to the third & second largest sprockets and won't drop back down after cable adjustment.
The RD clicks into position every time so am I correct in narrowing it down to a worn chain not catching onto the teeth? A few members indicated my chain may need replacing in an earlier post. Any suggestions? Thanks.
