Rusty Rocket
Hi, so I’ve just started riding again, and aware that new bikes need a bit of bedding in with stretchy cables etc, and I’ve looked around on the web for an answer but haven’t found it, hopefully it’s not too daft a question!
My bike (folder) has 1 cog at the front, and 8 at the back. I took it out for its first ride yesterday and I struggled/failed to get it into first gear.
I’ve read elsewhere that you shouldn’t really go big cog to big cog (or small to small) but wherever I’ve seen this it’s normally referring to a 3 cog chainset.
So does the same rule apply to single cog chainset? Do I have an 8 speed bike with 7 useable gears or should I be able to use 1st gear, just need to tune it so all 8 are working.
Thanks in advance.
Thanks in advance.
