Winston said:This may seem a silly question, but is there a technique to shifting gear on your bike. Do you continue to pedal or do you coast when changing gear?
Thank you again in advance.
Winston
jimboalee said:On a Sturmey Archer hub, you have to back pedal about a quarter of a rev to let the mechanism change smoothly.
montage said:try and avoid when honking out the saddle....but even then it should be ok - depending on the quality of your gears
