Andy in Germany
- Rottenburg am Neckar
Another problem has cropped up with the same (!) bike.
This one is being built practically from scratch with a 3/9 setup. The rear mech seems to shift down fine up until the fifth gear or so, then it needs two clicks to move it to the 4th. After that it behaves until I click into 3, when it jumps past it to the big gear.
changing up is fine´. increasing tension makes it change better from fifth, but above fifth it clicks and rattles.
Any thoughts how I can cure this? I've checked the hanger is straight and even changed it in case I missed something. Is it a worn mech?
