After adjusting the front derailleur via the front shifter’s barrel adjuster, now the gears are changing properly and the chain is no longer rubbing onto the derailleur.
However, I’m now having some issues with the tension of the high gear shifter (in the front), I have to press very hard with my thumb to go up one gear (to the larger chainring) and, after the gear was changed, the shifter will not spring back to its original position (it will stay at the far end). I have to pull it back myself.
I have no idea on what happened nor what caused it, and I am trying to avoid visiting my new "LBS" as they will charge me an arm and a leg for it...
(They could quote me £90 on something where another bike shop only quoted £70)
  I tried doing it the lazy way first by squirting oil at everything but ended up having to do it properly in the end though . Now it shifts like silk
