Shifter cables - L/R choice for front/rear?
Shut Up Legs
Down Under Member
Is there a convention here, and does it really matter which you choose? I've just replaced the shifter cables on one of my bikes, and realised I've connected the front shifter cable to the right brifter, and the rear shifter cable to the left brifter, which is the reverse of what I previously had on this bike. No doubt I'll get used to the difference in time.
The only difference I can see is that with the previous setup, the cable routing where the outers meet the head tube was a bit awkward, as the outers would rub against the head tube, while with the current setup, the outers wrap smoothly around either side of the head tube.
classic33
Leg End Member
Like brakes, I can't see it making any real difference. Unless the cables cross, possibly catching.
Broadside
Fleet, Hants
But isn't the left shifter only capable of moving between 2 gears?? Haven't you limited the number of years on your bike!
MiK1138
Glasgow
Do you mean brake cables?
MiK1138
Glasgow
yeah mine too, was like that when i bought it and as a lefthander i didnt bother to change it. sure confuses others when they ride it though
Pontefract
The OP said shifter cables.
