Sheared off braze-on.
Donger
Convoi Exceptionnel
Quedgeley, Glos.
A while ago I removed all of my pannier racks to lighten my bike. This included two front racks that were each mounted on a pair of braze-on bolts on the front (steel) forks. After removing the racks I put the bolts back in place and forgot about them.
I recently noticed that the bolts were getting a little rusty, and set about replacing them. Unfortunately one of them had seized in place, and sheared off when trying to remove it. Any advice as to how to remove the remaining seized up end of the bolt from the fork? Penetrating oil and pliers or any ingenious solutions that have worked in the past for any of you?
Drill, or if you pop in Aldi they did have some seized bolt remover bits for a drill, they may have some left, but.... it's a bit risky on a nice frame.
Take it to a proper bike shop.
simongt
Norwich
Looks like you'll probably have to drill it out. If so, make certain that you have the fork solidly clamped and a VERY steady hand on the drill.
Donger
Donger
Convoi Exceptionnel
Quedgeley, Glos.
How much of it can you get hold of?
Only a couple of mil exposed, and not a straight shear off. I was wondering whether it would be possible to weld something to the exposed remaining part of the bolt to get more purchase before having another go at it ..... but seems a bit Wallace and Gromit as a solution.
screenman
If you have the equipment and skill I can see that working, it is sometimes used in the motor trade.
Tim Hall
Crawley
Is the braze on on the edge of the fork or set into it? If the former, can you get to the other end of the sheared off bolt?
steve50
Disenchanted Member
West Yorkshire
squirt it daily with plusgas, get a stud remover from Aldi, drill the remains of the bolt carefully, squirt with plusgas, whack it with a hammer carefully , squirt with plusgas, insert the extractor and screw it out.
The welding idea will work.
Personally I'd use TIG and drill a countersunk hole in a flat piece of bar and weld it over whats left of the thread.
Allow to cool and the heat from the weld will loosen it. A little twist left and right and out she comes.
Paul G
keithmac
Welding is and idea but if it doesn't work out you end up with hard metal to drill out.
Some new sharp decent quality drill bits and flat it off/ centrepunch before you start..
