Richard A Thackeray
Whilst checking the brake-pads (or trying to) yesterday evening on my CGR, I rounded off the head of the small screw locating the pads
RS785 calipers
I guess it's my fault, for
1. Over-tightening
2. Ought to have added the smallest amount of copper-grease behind the screw-head
there's been some galvanitic corrosion over winter?)
Thankfully, there's probably another 4 - 5 months wear & tear left in it (hopefully)
Now, the problem is removing it.....
1. My father-in-law has a Dremel, so grind off the head, & drill it out, if he has any bits that small?
2. After drilling out, replace the current screw type, with a plain shaft, that can be simply circlipped?
(or, accept that the replacement -standard- screw will be loose, but it only keeps the pads in place, not locate them!)
3. 'Bite the Bullet' & take it to one of the local shops, & accept that a new caliper may be needed?
Or, other suggestions, please
RS785 calipers
1. Over-tightening
) but before resorting to drilling and other butchery I would keep trying to get that screw out by natural means.
