roadiewill
- Wiltshire
OK Im not sure if all turbs have the same general setup, but Ive just bought an elite mag lite turbo and just want a bit of advice on setting it up.
Basically, do you remove the cap on the right hand side of the rear spindle or leave it on?
Secondly, how tight do you tighten the clamp on the turbo - until it cant tighten any more or just a little bit?
Also, is it normal for the rear end to be higher than the front end and how do I solve this - just whack a few books under the front wheel?
thanks
thanks
