I posted recently about Joe Blow pump head washers - I object to having to buy a whole 'rebuild kit' when all I (and most people) need normally is the appropriate rubber washer. Apparently dealers can order them - 99p for 10 (+VAT??), to restock their Topeak pumps spares kits. Shame you and I can't order direct - I haven't found a supplier anyway, and the wholesaler didn't offer!
I've extended the life of mine by placing a fine O ring between the washer and the screw on cover - increases the pressure on the rubber - same principle as accountantpete's thin plastic.
