Rupie
The rear Hub and freewheel of by Bianchi cycle has, as you would expect, got to the point it needs a service.
The Hub is a Reparto Corse unit. I have managed to remove the 10 speed shimano 105 set of cogs but am unable to get into the bearings of either the hub itself or the free wheel. Normally there are two cone screws, either side that you turn but the one side of the hub is tapered, so knowhere to fix to. On the freewheel side there are two nuts, one cone but the inner one is recessed so far into to freewheel housing so no spanner of any type can get to it. I understand some freewheels are not user servicible but I should be able to get to the normal wheel bearings.
I have attached two photos to help explain.
Thanks
Thanks
