Seed sowing compostIm
pawl
I’m having problems with the above compost.I sowed Beetroot and Marigolds in pots .Both germinated . First leaves emerged .Something has nibbled the plants off at compost level,As I have had this problem before I put the pts on a sunny window sill. Can only think that there is something in the compost.
Might try a John Innes seed sowing compost Wondered if anyone else has experienced this problem.
tom73
Yorkshire
Are you sure they’ve been eaten ? Are they totally missing or just keeled over ?
In which case its more likely to be damping off.
pawl
pawl
They are totally missing There is a fraction of the stem visible just below the surface. This happened last year as well prior to that I’ve not had a
Thanks for your answers.
Glasgow
Happens to me quite often, it's slugs.
I had good results starting seeds with coco coir (link might not work, the issue is getting fixed by @Shaun) but, of course, the minute you put the seedlings in the garden they get chomped on.
