Securing cleats
ScottyB
Bournemouth
My cleats seem to move very slightly after a few rides - is this common, or am I simply not tightening them enough?
I am also wary of over-tightening them though! What is the best way to do this to get them nice and secure?
ianrauk
Tattooed Beat Messiah
Rides Ti2
Give it some welly. You don't want them moving.
ScottyB
ScottyB
Bournemouth
Cool, thanks. You can't move them by hand, just over a couple of rides they are clearly moving.
If those of you heavy handed guys haven't broken any threads then I will go for it and hopefully get them sorted!
Am I missing something, or is your display pic @Andrew_Culture of this parish? :scratch:
Now you mention it, I've never seen ScottyB and AC in the same thread at the same time, spooky :tongue:
Rob3rt
Man or Moose!
Manchester
Tighten them some more!
Depending on the type of cleat, it is worth using a torque wrench if you can, the bolts with Look cleats are absolutely shite and it doesn't take all that much to mash them.
The cleat bolts do need to be really secure, but if they corrode (and that can easily happen given that they are often wet and subjected to salt spray at this time of year), they can be impossible to remove. Therefore, do them up tightly, but only after you have used a thread sealant like blue Locitite. Not only does it prevent the cleat bolts coming loose, but the sealant stops the threads from rusting so that you can undo them when you need to.
Similar threads
