Seatstay Repair - do I need to remove handlebars and forks?
grellboy
Seatstay snapped recently. Can get it removed - reasonably locally - but when I phoned they said remove everything - chainset, derailleurs, forks etc. Have done most of it, but stopped at forks, headset, bars etc, coz I reasoned as they are at the other end of the bike they shouldn't get in the way. Anybody else had experience of this? Also, if I do go all the way and take everything off, will it make more sense to cut the cables by the levers, or leave them all in - Bike is internally routed so wondered what was least work-intensive way when it comes to reconstructing? Photo attached just for clarity. IMG_20211120_125403.jpg
grellboy
grellboy
When I say removed, I meant repaired. 😂
grellboy
grellboy
I'd remove as the repairer may want to upturn frame in a jug, so bars and forks will get in the way
OK. Thank you for your reply. So what would you suggest for the cables? Cut off at the levers so I can leave cables threaded through internal routings or just rip them out altogether? The bloke did say I can leave the cables in but I don't know if when I take it to the shop afterwards for re-cabling whether they'll want the cables still fitted so it's easier for them to rethread or not?
C R
Worcester
If in doubt ask them those questions, we can only guess.
raleighnut
Why cut them off, just unhook the nipples
  • Like
Reactions: C R
Ajax Bay
East Devon
Go on then: tell us how your seatstay snapped.
Could it just not cope with @blazed amounts of power?
