I am not sure that you mean theclaud, I am pretty sure that a frame will also have a safety margin built in. But you should refer to the manual/manufacturer re. how much post must be within the frame because the min insertion on a seat post, may not necessarily meet the requirement of the frame set so you may already be approaching the safety margin of the frame, then if you go and do as the OP has done and raise it an additional 3-4mm you may end up outside of that margin of the frame, even if you are within the margin of the seatpost. Probably pretty rare that a seatpost's marked min insertion is off far enough to pose significant risk, but it is worth checking if you are on the limit.
The min insertion marked on the seat post refers to the minimum amount of the post that must be inserted into the frame to avoid the seatpost failing. It does not refer to the the frame failing.
If in doubt, make sure you get a seatpost long enough to sit in the frame a couple of cm lower than the bottom of the seat tube and top tube intersection (obviously you need to use some judgement here because frames have different geometries). I like to have 1/3 of the post or a bit more at least inside the frame.
If you are a weight weenie, buy a longer post, make sure your setup is as close to perfection as possible, then chop off the post so that you only have as much as the min insertion within the frame. Will achieve best fit for minimum weight.
