Thank you.outer of the seat post inner of the tube it goes into
That makes more sense, thinking about it. Good job I held back on ordering it earlier todayI think you'll find it's the outer diameter of the seat tube, not the inner (which to all intents is the same as the outer diameter of the post).
which is not the same as the seat post clamp diameter.......seatpost size should be stamped on the bottom of the seat post.
