no, not that. pretty sure I have posted this on here already so please do a search - i cannot be bothered right now to post the photo.
basically what I found happens is that as you do up the clamp, the open ends of the clamp start to bend so the force is not going in to tightening the post but bending the clamp!. you can see this as the open ends are no longer parallel.
what I did was to put a washer (thickness carefully selected) in the gap so the outer part of the open ends meet the washer and as the bolt is further tightened, the inner part of the open ends are forced together thus clamping the post.
hmmmmm ^^^^ if that doesn't make sense, I'll dig out the photo.
