I'm a solid 330 lbs, and riding tends to be quite painful. I understand that there's adjustment and commitment required, but surely there are ways to compensate for poor core strength and a tendency to rest all my weight either on my butt or my hands.
Advice?
Hi and
Some of what you are describing will be adjustment, but it helps if the bike is properly fitted to you which should make things comfier. You want to make sure that the saddle is at the right height, the bars are the right distance away from you and that you are sitting in a comfortable position. Do you have a bike shop near you that could help with that? If not, have you any cycling friends who could help?
If not then as a rule of thumb, set the saddle at a height where your leg is straight when the heel is on the pedal at the bottom of the pedal stroke and the bars in the comfiest position you can get, preferably not so low that you are leaning on them too much. Take a set of tools out with you on a test ride and keep stopping and adjusting things until they feel 'right' to you. If your saddle is too low you will feel it on the top of your thighs, whereas if you feel like you are rocking in the saddle then it's a bit high. Also try setting the saddle flat front to back, too far forwards and your weight is all on your arms, whereas too far back and the nose is sticking in somewhere tender
Then there's options for replacing/adding bits which may make things more comfortable. Padded shorts are good, partly for the padding, but also because they are designed not to have seams that rub when you are riding. Bar ends can be a good investment for flat bar bikes as they give you more hand positions (for racer style drop bars I find spinning them back a bit is more comfortable).
Also one person's comfy saddle is another persons instrument of torture. A comfy saddle should support your 'sit-bones' rather than the softer stuff in between. You can get some bike shops to measure this, or do it yourself by sitting on some aluminium foil on a cushion and measuring between the dimples left when you stand up. As a good starter, many people find the Charge Spoon (mens) and Ladle (womens) saddles a good starting point, but as I said it's a very personal preference.
Best advice of all though is to get out there and enjoy it. Don't push too far to start with, and slowly work up the distance. You'll be finding it easier and more fun quite quickly as you improve and your body adapts. Have fun
