goo_mason
Champion barbed-wire hurdler
- Leith, Edinburgh
I'm still being plagued by the creaking seatpost on my SCR2. It gets temporarily cured (usually) by removing the seatpost and shim, and cleaning the shim up, then regreasing and re-inserting.
I've taped up the slot in the seatpost tube on the frame to stop mucky water getting in when it's wet, but that's not helped.
I'm considering getting a new seatpost that'll do away with the need for a shim. The trouble is, the seatpost diameter marked on the frame is 31.7 (I think, or is it 30.7 ?) and the closest size I can find online is always 31.6. Therefore there's a 1mm difference that'll probably creak even more unless there's a shim.
Anyone fitted a seatpost that's 1mm out without any problems, or did you all have to use a bit of a Coke Can as a thin shim ?
