SatNavSaysStraightOn
Changed hemispheres!
- ɐᴉlɐɹʇsn∀ 'ɐɹɹǝquɐƆ
I have some 2013 Fulcrum Racing 7 CX's and last May took the easy way out and use a bike shop to get the bearings replaced whilst my old bike was off the road (cracked carbon forks)...
Since then I have covered way too much distance and the front wheel has picked up some lateral play and a drumming noise.... before long the rear bearings will also need replacing as some of you know, I don't exactly stay on road all the time and the lane I live down is err... well dirty/mucky is probably the best phrase....
I don't want to go down the wheels back to the shop route (though I probably should because I haven't covered more than 4,000km since May on those bearings but getting the wheels to Chester and dealing with warranty (5,000km) is too complicated right now and I can't afford to have my bike off the road and have no way of getting the wheels to Chester as it is... and bike shops don't generally like the 'can you do it while I wait' approach.... so I have given up.... it is probably cheaper just to replace them myself...
Having tracked down the bearings I need (Fulcrum 4-R5-004) which is a 28x12x8mm bearing with a code of 60012RS can someone please tell me, bearing in mind my requirements approaching winter, my track and the likes... which of the 16 results I should be getting... I think it is either these or these but I am definitely having one of those days...
Or alternatively if you can point me in the direction of someone who has the Fulcrum/Campagnolo ones in and in stock I would be most grateful or some site you know (I have never used the site linked above) etc...
thank you
thank you
