SDP combination pedals?
Alcdrew
UK
My Shimano M324 pedals have come to the end of there useful life so I need some new pedals, need to be usable with my SPD shoes for my commute to work and normal shoes for when I go out for a leisure ride with my family, can anyone suggest any that are good?
lazyfatgit
Lawrence, NSW
If you've been happy with the current pedals, why not just get a replacement pair?
I had a pair of cheaper copies which didn't last as long as expected. I've now got a pair of BBB ones as my LBS had these in stock and they seem much better made than the cheaper ones. Time will tell. Only issue I have is they are a little narrow for my big feet on the normal side, fine when using SPD shoes.
Alcdrew
Alcdrew
UK
Thanks for the input, LFG I have been happy with the ones I have and would mind another pair but it's always good to see what else is out there had mine for many years/ miles, some times a change is good.
Jim, I do like the look of those thanks. Hadn't seen them before.
LazyLoki
I've got the A530s and they're a really good pedal. The SPD side is well made with a good amount of adjustment and the flat side is a decent size. Shimano also make a slightly cheaper A520 pedal but it's flat side is smaller. I only have size 8 feet and I found it to be a bit pokey.
