SCR 3 08 Crank Length
Mortiroloboy
If it's any help the Truvativ Touro crank set on my SCR4 '08 were 170mm, measure ctc i.e. centre of the hole that the crank bolt goes in , to the centre of the hole where the pedal axle goes, not sure which crank set the scr3 has, but as the frame is exactly the same, as are the wheels Alex 22's then in all liklehood the Tiagra? cranks will still be 170mm.
When I put the Campy Veloce cranks on at 172.5 I did suffer with a bit of toe overlap, just something you need to BIM when changing cranks
roadiewill
roadiewill
Wiltshire
Just out of interest, how much do you think I would get if I sold the SCR3 to upgrade to a different bike? Bearing it mind that its only 8 months old, in good condition and with an ultegra rear wheel?
