Time Waster
For some time now our freesat channels have had issues. It went off completely for 20 minutes earlier this year I noticed the cable plug was loose so I sorted that out and it was OK. But the last month it's gone off as in no signal from the satellite but only the aerial. It came back on after I turned the TV off for 15 minutes. Since then every time the wind blew the picture froze or went blocky for a second or two. Now it's off without any satellite signal. In the wet too it seems bad.
Both the aerial and the satellite feed cables go into a box with one outlet cable to the TV. That's why I'm pretty certain it's not the cable I fixed but to, do with the cable feed from the satellite or the satellite dish itself.
Does anyone have a clue why bad weather has this effect? Any advice on fixing it? I'm thinking the cable might be a bit loose or not fully sealed and connected at the satellite dish receiver. There seems to be a plastic piece around the cable at the bottom of a loop leading from the receiver.
How easy is it to replace the dish? Would this be a good option? I can reach if by ladder as its on the side of the house but I've not much experience with TV cables. What is needed if I was to try and take the cable out of the receiver and reattach? Or is that a non-starter? Are they usually sealed in for weatherproofing reasons? Anyone know?
