Sat Nav for Bike
Sam Kennedy
Newcastle
I'm looking for a sat nav which can record my bike rides, but which can also be used for normal in-car use.
I don't want to spend more than £100, but if there is anything decent which is just over that then I don't mind.
I don't if you can get anything integrated (copes well on the bike and the car). The Garmin 205 can be got for not far above your budget. I use the 305 version (I think the only difference is HRM and cadence) its really useful for recording rides but its only of limited use as a gps.
luplowe
Bournemouth
Bike sat navs like Garmin Edge dont talk, they beep at you with directions so not really ideal for car use,
The edge will do everything you want as far as the bike goes, but mine was over £300 with the map..
Billloudon
Escocia
Nokia 5800. GPS and maps included, and you can download Sport Tracker for free (this records your rides).
Have a word with your moby provider and you might get the phone for free. Battery life would be your only issue if you're on long rides, but there are workarounds.
Paul,
Don't you require internet access for this?
dodgy
Billloudon said:
Paul,
You can preload the Garmin maps, no net access required once they are loaded via your PC. Sporttracker needs net access in order to either live track your ride, or to upload it to the Nokia site when finished.
Will1985
Norfolk
Garmin Edges are not sat-navs. The newer ones with better maps might tell you your location, but they aren't great at routing and can't talk at you.
On the other hand, Garmin Edges are useful training aids - capable of recording data during your ride for you to analyse later, and compare against other rides.
Push your budget to £150 and you might find a 305 (get the GSC10 too).
I've got a HTC magic from vodafone, which can do just that. It runs the Android operating system, so there is lots of free software available for it. I use My Tracks to track my rides and it works well.
You can get free sat nav software for it as well (Nav4all) although it isn't the best. However, I know you can get paid for sat nav for it as well (about £30 I think).
Oh, I forgot to add, that the battery is pretty good (I reckon I could track 5 hours no problem). However, you can buy a USB battery pack that you can leave connected to your phone if you need to track for longer.
johnnyh
Somerset
well I can put a street address into my 605 with UK map pack and it'll calculate a route and take me to it turn by turn, yes it beeps and gives a visual instruction rather than the voice command, but that aside I would say it is a sat nav and it works pretty well.
jimboalee
Solihull
Will, you are correct. Garmin Edge are not Satnavs. they are Global Positioning System enabled bike computers.
They are also training schedulers, data recorders, mass storage devices and when set up correctly with an 'Auto routing' facility map, they can be used as a Navigator.
