cyberknight
- Land of confusion
title says it all ,
as the edge of the padding doesnt go under the hull recently i have started get some soreness in the area that sits on the edge even with shorts .I have used these saddles for a couple of years with no issues when i couldnt get on with the flat narrow saddles i was ok with .
I did try the narrow flat one again and although not as bad it still was nt right after a couple of hours then remembered i have the model they were based on the charge scoop on the commuter and i dont seem to have the same issues as the material is attached in the traditional way under the hull of the saddle
