Any advice for setting correct saddle height ?
For example, should the saddle generally be as high as possible ie it would be difficult to sit on if holding yourself stationary with 1 toe balancing you on the ground ? It is probably a major advantage in terms of applying force if the saddle is on the high rather than the low side but there must be a point were it gets a bit ridiculous ? It looks to me when I see pros on their bikes that saddles almost without exception seem set very, very high indeed.
Ta for any and all comments.
