Justinslow
Lovely jubbly
- Suffolk
I guess we'll never know, but it could have been and it equally could not have been visible? I'm not sure if it means the issue was within the head tube or just below?"The public are being warned there are still almost 2,000 faulty bikes on the streets. Jonathan Weatherley, 43, of Church Street in Sible Hedingham, died when he came off his bicycle after braking suddenly in Lorkin's Lane, in Twinstead, on August 23 last year. It is thought he could have been avoiding debris or animals in the road and he was left there for 90 minutes until a passer-by spotted him and phoned paramedics at 3.40pm. His bicycle, Kinesis Racelight TK2, had a bonding failure between two parts - the fork crown and the steerer tube."
A recall has been issued. If you have that bike, go find it.
More detail from Leigh Day's site at https://www.leighday.co.uk/News/News-2016/June-2016/Coroner-finds-cyclist-died-after-forks-separated which repeats the quote from Senior Coroner Caroline Beasley-Murray: “Jonathan Weatherley probably applied braking through his front brakes for some unknown reason, causing the bonding between the carbon fiber blades and aluminum crown to fail as a result of the fact that the bonding material had not adequately bonded these two components together. Jonathan died as a result of his injuries sustained in this accident.”
I wonder if any problem would have been visible before it failed?
Fixed.Unless this has been posted before on the forum, perhaps a change in the thread title to the bike concerned may get peoples' attention?
We will probably never know and I suspect it might not have been visible.I guess we'll never know, but it could have been and it equally could not have been visible? I'm not sure if it means the issue was within the head tube or just below?
A very sad story.
The fork blades bond with the alloy crown failed which caused the fatal accident which precipitated this recall. So you may wish to think again.Mine's got a full alloy steerer so doesn't look like it's affected after all.
The recall applies to forks with an alloy crown and carbon steerer. Forks with a full alloy steerer are specifically mentioned in the recall notice as being unaffected.The fork blades bond with the alloy crown failed which caused the fatal accident which precipitated this recall. So you may wish to think again.
Don't alloy-carbon bonds use a different process to an alloy-alloy one?The fork blades bond with the alloy crown failed which caused the fatal accident which precipitated this recall. So you may wish to think again.
Kinesis is spelled wronglyFixed.
Where?Kinesis is spelled wrongly
