Rusty chain
Pedal pusher
Alloa
I've offered to strip and clean an old bike for a friend. It's been sat outside for quite a while and the chain is rusty. He doesn't want to buy a new chain so any suggestions on how to clean the chain?
ianrauk
Tattooed Beat Messiah
Rides Ti2
Lube, Wipe
Lube, Wipe
Lube, Wipe
That should do it
Sharky
Kent
As above.
If too many of the links are seized, then probably not saveable.
7/8 speed chains are only £7 or so. You could just treat him to a new chain if he is your friend. But it might show up a worn cassette as well.
Is the chain on your own bike compatible? Treat yourself to a new chain and give your old one?
wafter
Oxford
While I'm all for saving stuff there's also the question of your time - one might interpret said mate's request as a p*ss-take; essentially requesting that you spend a disproportionate amount of your time trying to salvage the knackered chain as your time is worth less than the few quid it would cost them to replace it..
Have you run it by a chain checker? Of course any salvage attempts will be worthless if it's worn out already.
All that said; worth removing it and slinging it in a jar of paraffin for a bit to try and free it up..?
biggs682
Northamptonshire
WD40 or an other brand all over the chain then take it for a ride and see what happens or how far you get .
GuyBoden
Warrington
As above.
Lube, Wipe
Lube, Wipe
Lube, Wipe
Lube, Wipe
Lube, Wipe
Throw in the bin. :laugh:
