Rowing machine recommendations?
GlamorganGuy
I want to buy a rowing machine to help with general fitness. Looking to spend up to £250 at a push but ideally a fair bit less... There's a daunting range out there, anyone got one that they can recommend personally?
Milkfloat
An Peanut
Midlands
I can only recommend a Concept2, they are the gold standard which you will see in every rowing club in the country. however, they are significantly more expensive (~£1000) unless you are lucky enough to find one second hand. Second hand is not a problem as they are bulletproof and you can still buy spares for the first model released 40 years ago.
PK99
SW19
Seconded
Nothing comes even close
Bonefish Blues
Banging donk
52 Festive Road
Because I had a choice of the two, and went with my preference, my vote goes to...
WaterRower
Because not everyone wants to be an athlete with a C2, and they are lovely to use, whilst still being a very serious piece of kit. Standable-up after use, too, if space is at a premium.
Also supported down the each nut, bolt, widget and water tank.
A genuine alternative which is worth looking at 😊
PK99
SW19
WaterRower
I bought a water rower as I gibed at the price of the C2 - it sat at home unused while I used the C2 at the local gym where I swam.
C2 develops a much better momentum and rhythm.
Bonefish Blues
Banging donk
52 Festive Road
Cyclists row too, you know! :laugh:
