Route Advice – Manchester to Ashby de la Zouch
therams
Manchester
OK, on Friday I have the day off work and am planning to cycle from Manchester to my parents house in Ashby de la Zouch (in the midlands near Donington Race Track).
I normally plot my routes on map my ride and then upload them to my Garmin 305. However, when plotting the routes I normally have some idea of what the roads are like.
Does anybody have any route advice, I think I will head to Buxton and then on from there. But I could also follow the route of the old A50 to stoke, but I don’t know that area at all well.
Macclesfield – Leek – Ashborne also looks good on Google Maps!
Basically I want to keep the distance to around 75 miles and avoid busy roads.
Missing out Buxton, would also let me miss out some hills?
Any advice is appreciated thanks!
garrilla
Liverpool
And will you be going to Nottm on Sat?
garrilla
Liverpool
I'll be interested to know what that route is like from Congletron onwards. I occasion muster the motivation to do Liverpool-Nottm but I go/struggle over the peaks, so its maybe time to try a lighter ride and as I'm going to West Nottm (Bramcote), your route would suit with a bit of adaption at the end.
therams
therams
Manchester
Yes, I chose this route to avoid the Peaks, I have a few backup routes as well, just in case.
I will let you know how I get on.
therams
therams
Manchester
Well the whole ride (75 miles) took me just under 6 hours, not to bad considering the conditions. The first 30 miles, were torrential rain and probably the only part of the route that I would change.
I set of at about 8:00 and at that time of the day the A34 to Congleton was too busy to be relaxing. With the rain, I did not feel too safe, even with high vis and back light on. However, once I reached Congleton, the rain eased and the roads became quieter. It was a mistake to think that as I had missed out Buxton, I was missing out the peak district! My Garmin recorded 4500 ft of climbing over the 75 miles, way more than I expected and way more than I had every done before. However, I got my head down and when I arrived at my parents; the feeling of accomplishment was fantastic.
So would I recommend the route, if you miss the A34 at the start and like hills then yes! The last 25 miles through Derbyshire were fantastic!
To be honest on a Sunday morning, with no rain then the whole route would have been great.
jimboalee
Solihull
Some advice for those who plan a LONE ride across country.
Stick to the main roads.
Reason 1. - If something disasterous happens, the paramedics can find you easier.
Reason 2. - There are more shops on the main roads.
Reason 3. - Signage is better on main roads. You needn't have a Garmin to guide you.
Don't go down single track lanes on a LONE ride. If another vehicle, whatever size, makes you ride into the hedge and clears off, you might be lying there un-noticed bleeding to death for a long time.
Most important of all.
Have your mobile phone in a small pocket where you can get at it, even if you are upside down in a drainage ditch.
Llandudno
I wish I'd seen this before - I would have warned you the A34 is unpleasant.
From Wilmslow its possible to take quiet lanes via Chelford, Windyharbour and Swettenham to get to Congleton. Only adds about a mile too.
therams
therams
Manchester
I appreciate what you are saying about having a mobile phone to hand, in case of an emergency. But I think a well planned route, on single track lanes can be fantastic. Shops can be planed in as well and with a GPS or map, you can find your way easily.
Surely, that's part of the pleasure of cycling alone, the isolation, time to really appreciate the country side.
I agree that being left for dead in a ditch is not ideal, but if everything we did was 0% risk we would never leave the house.
therams
therams
Manchester
Yes, I had originally planned a route past Jodrell Bank but changed my mind at the last minute. In hindsight, not worth it to save a few miles.
