bbbbbbbbbbbbbbbbbbbb
Strictly only dry use, road bike, Muc Off C3 dry lube: Roughly how many miles between each re-lubing of chain? Thanks.
Strictly only dry use, Muc Off C3 dry lube: Roughly how many miles between each re-lubing of chain? Thanks.
When it looks as though it needs doing.
I assume when you can’t see it ? C3 is UV luminescent and comes with a small UV torch, the point is that you can see the stuff on the chain. But i would always apply it before every ride.
Just go by taste, when it starts to taste sharply acidic you need to add a drop or 3 more oil.
👍more than 100 miles, less than 300 miles. The rest depends…
