GregCollins said:
serious question... are Rohloff's really as good as some make out? A real serious competitor to derailer type gears or a draggy leaky high maintenance expensive failure prone box of garbage.
cos I'm might seriously think about a rohloff equipped mtb because I am sick of rear mechs getting full of crap and along with front mechs not shifting properly.
Looking for first hand experience or, if second hand, at least experiences in the public domain I can read up on myself.
Dificult questions since my impression is there are generally two types of Rohloff owners. Those who love their hub fanatically - big majority - and those who turn away deeply dissapointed and sell it agaion (a small but vocal minority) . The Rohloff really polarizes, problably due to high high price. I think it´s psychology which is behind this phenomeon. When you spend so much money on something which you also could get much cheaper you have to reassure yourself that this was completely justified.
I have a Rohloff on my recumbent which I bought used so I did not have much of a choice
. IMHO these are the most important pros and cons:
Pro:
- smooth and idential gear ratios between all gears. (Uncounciously I switch gears much more often with the Rohloff to keep the same pedaling cadence)
- you can change gears while standing (very convenient on a recumbent)
- gear is protected against hud ect. (more important on an MTB than on a recumbent)
- The back wheel has more stability because it is spoked symmetrically, broken spokes are less likely
- shifting of gears is very convenient
Con:
- extraordinarily expensive
- it´s noisier than a derailleur gear, especially in the lower gear. The noise the Rohloff makes partly depends on the particular frame you´re using. With some alloy oversided frame some people have real problems.
- the degree of efficiency (compared to a derailleur gear in perfect condition) is a little bit lower. Rohloff states this is not true but my subjective feeling is different.
I´d strongly recommend testing one before buying. The Rohloff is a beautifully engineered thing but it has its weaknesses. I love it for the idential gear ratios and the ability to shift gears while standing, but hate it for the noise.
I had no trouble with leaking oil or other issues and to my unterstanding from a similar forum in Germany those kind of problems are a rare expecption. The box really is more or less failure proof.
And just in case you really decide buying one: be sure to get one with the external gear mech. It costs a little more but makes life (removing the wheel, replacing the cable, ect) much easier.
