I'd go for the Road Morph - I have it - it's an excellent pump. I'm always amused by those super-mini pumps some style-over-substance roadies carry. They'd be bettter hanging them from their ears. Get the bigger pump then when out on rides you can generously/smugly offer them a real pump.
I have both, I use the road morph on the road bike coz it has the gauge and it is bigger so easier to get hold of and I use the mini morph on the hybrid and just pump thr tyres up till they feel right as the tyres do not need to be pumped up to such a high pressure.
I have a road morph and a racerocket, the rocket is not up to thejob if you want a decent pressure but it will get you home.
The morph does what it says on the tim and is worth the extra size.
You don't need to measure tyre pressure out on the road after fixing a puncture. Just get your tyre suitably firm and that will do. If you are that bothered about the exact pressure, top it up at home before your next ride.
As for CO2 ... I would always carry a pump as well in case I ran out of cylinders. (A friend of mine got through all of his cylinders on one long puncture-fest ride and then had to borrow my pump.) If you are carrying a pipe anyway, why not use that instead! It only takes a couple of minutes to pump a tyre up by hand so what's the problem?
