You probably do have a 1 1/8" steerer if you have a relatively new bike with an ahead stem, with allen bolts at the back. 1" steerers tend to be used on older bikes with quill stems with a single bolt on top. If you have an ahead stem, then yes, the answer is, the stem should slot off and the new one will slot on.
