Twilkes
I went over a pothole a few weeks ago, with the attached results. It affected braking, so I moved the pad a little lower and that's not really a problem any more. I've tried tapping it back in, including with a block of wood over the rim, but it's not really budging. Am I not using enough force, or is that just not a good idea? Haven't taken the tyre off and tried to bend it with a wrench yet, but would be happy to try it if it's likely to help.
Given that there are no other negative effects, and no evidence of any cracks, or any damage getting any worse, should I be concerned about this? The rims are pretty heavy duty, and it only affects the very top edge of one side, the majority of the rim surface is fine.
