terry_gardener
- stockton on tees
basically is it hard to ride on frost, is there anything you have to watch out for.
As over the previous responses but I would say treadier or knobbly tyres depending on your bike rather than pure studded, however, that may be just my preference.
If a road bike, check the wheel and frame spec, you may get decent treaded or slightly knobbly up to 25/28mm.
If cyclocross, def go for 35mm knobbly (I gave these on mine and great so far this winter).
If hybrid or MTB, def go for 35mm or greater knobblies.
For the road bike or cyclocross, drop the tyre pressure slightly if very icy. Slower but safer.
Did that once ,a car overtook where an ice patch was so I ended up wheel spinning and then doing the clip less dive.Stay in the saddle on climbs to keep weight on the back wheel...otherwise you may find the back wheel spinning and you not getting anywhere!
Frost I haven't encountered much problem with, black ice however is always to look out for. Usually around puddles, where the spray from car drivers have scattered across the road becomes black ice very easily, and will bring you down.
I understand your point and that's what's great about this forum, we can disagree without giving off verbal.Knobbly tyres will give good grip in fresh snow but if anything will give less grip on ice than a more road oriented tyre due to less rubber in contact with the road.
couldnt agree moreThis is NOT a head phone comment!
Learn the noise your bike makes on the road, and listen to the tyres it will change to a low "hiss" when on frost and be silent when on ice
This gives you a more accurate idea of the surface you are on
