I purchased this bike about 11 months ago but had a change in circumstances so haven't been able to use it due to other commitments. <200 miles since new.
Cost £1200 as currently equiped with carbon seatpost and Shimano 105 pedals and had the bars regripped with gel inserts and padded tape.
Suit rider 6ft 2in +
For sale £750 (located Bedfordshire)
Ribble Gran Fondo Sram
• Ribble Gran Fondo Carbon Road Frame XXL (58cm C to Top)
• Ribble Gran Fondo Carbon Road Forks 1 1/8-1 1/2 ITS
• ITM Headset 1 1/8- 1 1/2 Hidden 45x45 46mm
• Sram Apex White 10 Spd Groupset
• Sram GXP Team Cups English
• Sram Apex White Brakes Road
• Sram 10 Spd PG 1050 Cassette 11-32
• Sram 10 Spd PC1050/1 Chain
• Sram Apex White 10 Spd Chainset Compact 175 34/50
• Sram Apex White 10 Spd Front Gear Braze-on
• Sram Apex White 10 Spd Rear Gear Medium (max 32T)
• Sram Shift/Brake Levers Apex White 10Spd w/cables White
• ITM Pr Whls Aero 2.4 8/9/10 Shim
• Deda RHM 01 Bars White 46cm
• Deda Zero 1 Stem White 130mm
• CSN Superleggera K10 Saddle White
• CSN Carbon S.E. Seatpillar 31.6 400mm
• Vittoria Rubino 3 Rigid Tyre White/Black 700x23mm
• Yaw Butyl Inner Tube 700x18/25 SV42mm
• Deda Cork Ribbon Handlebar Tape Black (replaced with gel insert and padded tape)
• No Pedals currently selected. (Black Shimano 105s fitted)
