Revival/ charging of rechargeable batteries (AA/AAA)
palinurus
Velo, boulot, dodo
Watford
Ni-metal hydride types.
Left my Dinotte on over the weekend so have drained my batteries (4 x AA) nicely. The (Engergizer) charger I have at work is sniffy about very discharged batteries and throws up a row of crap battery symbols and refuses to charge them. My previous Vapex charger didn't do this. Can anyone recommend a more tolerant charger/ give me some tips on battery revival?
I have my spares in the charger and they are cooking nicely, normally they only get partially discharged and I top them up daily.
palinurus
palinurus
Velo, boulot, dodo
Watford
[QUOTE 4031917, member: 45"]I'll be watching this with interest. I have similar problems with my smart charger. I used to bang the dead batteries into a cheap standard charger get get some energy into them, then put them in the smart charger, but I've lost the old standard one.[/QUOTE]
That is exactly what I used to do! I dropped and broke the transformer on my Vapex charger.
Milkfloat
An Peanut
Midlands
If you don't have a cheap standard charger around to boost them to something recognisable by the smart charger, you could try boosting from another AA/AAA.
Hardrock93
Stirling
Don't know of this will help, but I had a similar problem with my charger for an Olympus camera battery. It wouldn't start charging if the battery was completely flat. I found that if I connected a new Duracell AA across the discharged battery for a couple of minutes, it gave it just enough of a charge such that the charger would then start doing its stuff.
Mile195
West Kent
Sounds like you have an "intelligent charger" that monitors the output of each battery as it charges and modifies the current accordingly. I have one too, but if the battery is too discharged it throws up "null" and doesn't do anything.
In that situation, I put the batteries in a "dumb charger" - that is, a cheap charger that just charges at a given rate for a given amount of time. That's the kind you often find provided with a set of rechargeable batteries (and costs about £15 in the supermarket). A couple of hours in that will get enough charge in for the intelligent charger to work properly.
deptfordmarmoset
Full time tea drinker
Armonmy Way
I've had a couple of batteries that have thrown up ''null'' and refused to recharge. What I'm now wondering is why there isn't a ''rescue'' setting on smart chargers, something that makes it act dumb for a little while. Or perhaps there is but I don't know of one.
the snail
Chippenham
had exaxtly the same problem with my energiser charger, this one did the trick - quite a handy one fir travelling too:
http://www.hotukdeals.com/deals/uniross-globe-trotter-pocket-travel-601586
Lonestar
Ha.came off AA/AAA years ago and now am a firm believer in 18650 batteries and their torches.Juts ordered five focus 590 torched from china to go with the others I have already got.
palinurus
palinurus
Velo, boulot, dodo
Watford
Gave them a boost with a new Duracell and a paperclip and I'm up and running.
I've got some really old AAAs in my desk drawer at work, tomorrow I'll try giving them a few volts from a variable power supply in the lab and see if I can get them to charge after.
migrantwing
I got my charger from an online retailer named 7dayshop. They sell all sorts of stuff. I got my charger and 4xAAA and 4xAA which are higher capacity than the standard batteries you buy, giving longer run times. Got them all for around £10.
mjr
I recently bought a new smart charger because it had a better display and I wanted to see what capacity was left in some of my batteries, but it is very sniffy about ones that have been discharged heavily in a low-drain device like a clock. My older tri-mode NiCd/NiMH/Alkaline charger manages to recharge them and doesn't seem to cause leaks or anything, but it does mean I still don't know what capacity is left. A review is http://www.geekalerts.com/battery-wizard-alkaline-recharger/ but I don't know if it or a later model is on sale anywhere.
I still have a dumb charger to sort our overly discharged batteries. I don't think rechargeable batteries are overly keen on low drain devices like clocks though.
