Restoration recommendations
rb58
Enigma
Bexley, Kent
My old Alycon is due a respray, and I've shortlisted Argos, Dave Yates and Mercian. Anyone got experience of any of these, or offer an alternative? It's for a respray, lug lining etc.
Thanks
Spokesmann
Keeping the Carlton and Sun names alive...
Plymouth, Devon
Ive heard good things about Argos and Mercian. Not cheap but top quality work.
davester65
Growing Old is Compulsory...Growing Up is Optional
I've just had two frames restored by Dave Yates (see my Dawes and Raleigh threads in here), again, not cheap but top notch work. I would probably go for the one that's nearest geographically.
PS For decals try H Lloyd Cycles at Penrith.
PPS If you want hi-res pics of my restored frames prior to build, pm me :-)
U
User482
Argos did a fantastic job restoring my Breezer mtb, including repairing a gouged chainstay, two colour paint and repro decals. My only complaint is that the paint chips a little easily. Cost about £200.
rb58
rb58
Enigma
Bexley, Kent
Thanks guys. Someone also mentioned the finish from Argos, so I'm not so sure about them. I have the transfers and have also managed to source an original brass head badge from France.
My local LBS recommended Colour Tech in Dartford (which is near to me). Anyone used them?
Cheers
rb58
rb58
Enigma
Bexley, Kent
Thanks @screenman . I was in the shed when I posted, and I guess I got carried away when I saw they were local. Too much bad press on Google for Colour Tech, so it looks like it's going to be Mercian.
Odd that Enigma use Colour Tech though as they're a top quality outfit and I've seen some of their work, which looks stunning.
Thanks all.
David.T
Member
Spain
Hi rb58,
Mercian have re sprayed three frames for me over time and all have been first class ,with perfect lining .
Photo attached of my king of Mercia re painted in 1987-88 and used continuously since. I would recommend them very highly Offer KoM in garden.jpg OIKoM head bage.jpg
Hello @rb58 do you have a local panel beater/spray shop nearby?
They may do the work for you at a reasonable cost. I suppose it depends on whether there is cycle specific work needed befor the respray.
Before and after pics would be good whatever you decide
GrumpyGregry
Here for rides.
Cheers
Fairly sure a couple of household name own brands use those Dartford boys.
