Replicating cleat positions
What's your tried and tested method to replicate cleat positions on a new pair of shoes ?
Keen to get the new set as per my current ones as they are now a great position !
Thanks
PS: this is for 3 bolt road cleats
Sharky
Kent
Just "feel". With look pedals having float, it's not that critical. The early black cleats with no float were a bit more difficult.
But not as difficult as the old toe clips. Used to ride a few miles without cleats, to make an imprint in the leather sole, before nailing the cleats in place.
Mike_P
Harrogate
A good starting point is to fit the cleats to the shoes eyeballed as being in the same position in terms of the fixing bolts as those on an existing pair.
PaulSB
I use a tape measure and measure from the rear of the shoe and then position the back of the cleat the exact same distance from the heel.
It's important to work from the back as different shoe styles can be longer or shorter at the front. That can't happen at the heel end.
T4tomo
its defo a bit of trial and error but measuring from heel is a good starting point. new cleats to old shoes i use the felt tip pen outline method on the sole.
pawl
I use tipex to mark the outline of the cleat on the shoe sole.when replacing cleatse
If it’s new shoes I try to position the cleat as near as possible to the old shoes Once I’m satisfied I mark as above
roubaixtuesday
self serving virtue signaller
Thanks
I use the unscientific methods.
But when getting fitted for a new bike, they used one of these, or something similar.
https://www.chainreactioncycles.com...laQhESQhUvRGcFDGGNYaAkSBEALw_wcB&gclsrc=aw.ds
Milkfloat
An Peanut
Midlands
I don’t think there is a scientific method as each shoe has different dimensions and thickness of padding. Like others the best I have found is measuring from the heal and then adjusting from there by feel. I have pairs of shoes with quite different positions even measuring from the heal, my assumption is that they are so different because of the different sole material and therefore flex and feel.
