deanE
- Falmouth, Cornwall
I have bought a secondhand Specialized Sirrus, which I am doing up for a JOGLE next year. It’s about 8 year old. I have replaced the cassette, to give me a lower gear ratio and the rear derailleur to accommodate, using Shimano Alivio. I have been impressed with the one I fitted to my road bike and it was easy to set up and changing smoothly, with Alivo shifters fitted. However, the chain is slipping on the chainwheel under load and so I have bought a new, Alivio, front chainwheel. The price was right and I thought that it might be better to have the same group throughout. However, this appears to go further on to the taper than original chainwheel, with the result that the front derailleur is not functioning. There is not enough adjustment on the front derailleur to ensure that the chain will shift off the mid to the small chainwheel, it is hard against the frame, and shifting up has the chain on the large chainwheel when the shifter is still mid way. The original equipment on the Sirrus was Nexave and the front derailleur still is. The cross section of the chain wheel / crank arm looks about the same so I am perplexed. If anyone can understand what I have described, and suggest possible solution, I would be appreciative. I have looked at Sheldon Brown, but it just gave me a headache.
