phil_hg_uk
I am not a member, I am a free man !!!!!!
I want to upgrade the chainset on my Secteur Elite to 105 I had a look at what is available and found this:
http://www.cyclechat.net/index.php?app=forums&module=post§ion=post&do=new_post&f=23
my question is which one do I need as there seems to be 4 different sizes 165mm, 170mm, 172.5mm and 175mm and what does this measurement refer to, also do I need to also change the bottom bracket for this one for instance:
http://www.chainreactioncycles.com/Models.aspx?ModelID=11726
or is the one on the secteur elite ok for this.
Also am I correct in thinking that if I undo the bolts on the non drive side of the crank and the remove the cap and knock the spindle through then the drive side will just slide out then refitting reverse of removal.
