I believe the axle to crown (A2C) distance of your forks when fully extended is about 470mm. Assuming 25% sag e.g. for general XC purpose that gives an equivalent rigid forks A2C of 470-25%x100 or 445mm for maintaining headtube angle/bike geometry. Many rigid forks are available with that dimension.
Well that is partially the theory, since the offset of specific forks will also make a difference to trail and therefore handling, but I don't know if Fox even publish those figures for their forks, and it is not always possible to find such figures for potential rigid replacements either. We will probably have to assume new and old are similar.
Obviously choice will also depend on why you want to switch, given the F100RL has lock-out? and at around 1.7kg it is not exactly heavy for suspension forks. Although the lightest rigid mtb forks can save you 1kg, many rigid mtb forks weigh over 1kg too.
Many replacement mtb rigid forks have 1 1/8" steerer for 26" wheel and standard 100mm quick release front axle. You will need to decide whether you want disc and/or v brake fittings.
Hope it helps.
