replacing a shifter
amorphous
My 3 speed Sora front derailleur shifter is kaput, and needs replaced.
(I think the spring is gone)
Do I need to replace it like for like, or can I use any similar Shimano 3 speed shifters (altus, acera)
cyberknight
I would replace it with a road one, mtb have a different cable pull ratio.
+1 to @cyberknight
Also, if you aren't replacing like-for-like, you will probably want to replace both shifters, as the new hoods will be a different shape so the bike will look and feel strange if you don't replace both.
As you have broken the front shifter, have a look on ebay, you may get a bargain. The rear shifter tends to be used much more, and thus fails more often so people will be more likely to be selling what you need. When I broke my Tiagra rear shifter, I could only find front ones for sale. FWIW, I happily easily upgraded from 2/10 Tiagra to 2/10 105s without issue.
Ajax Bay
East Devon
Take care that you choose an STI which is compatible with your triple FD. Your choice is whether to buy a pair or just the left one. Styles keep changing so you can match your RH Sora STI but the supply is limited. Agree with @cyberknight : plenty of pairs of STIs on e-bay and some just LH STIs. I 'won' a pair of Tiagra 4400 STIs last month.
