DCBassman
- The lumpy far South West
The plan is to replace the crummy suspension fork on the Trek Navigator with a rigid replacement. The current fork is 430mm crown to axle, 190mm steerer tube.
I'm not too fussed about losing some height from the front, it's very upright at the moment.
Questions are:
1) If I get a fork with a 250mm tube, can I use spacers above and below?
2) If I get a slightly shorter steerer, does that matter? There are already 2 spacers (5mm) between the two locking nuts.
3) Will the drop in height of the front have any significant effects?
Your expertise, as always, much appreciated.
Questions are:
