Replacement for Nokia Sports Tracker
CharlesF
Glasgow
I am converting from Nokia-ism to Andriod and want an equivalent app to the Sports Tracker.
I have tried Endomondo but it times the whole journey, whereas Sports Tracker can be set to pause if you are stopped for more than a predefined period.
What other ones should I try?
John the Monkey
Frivolous Cyclist
Crewe
I'm pretty sure newer versions of Endomondo (sadly not ported to symbian) have an autopause in them, Charles - a pal of mine mentioned it to me a bit ago.
benb
Evidence based cyclist
Epsom
Yes, Endomondo has auto pause when you stop. You can also manually pause it.
I have also used MyTracks which is good, but I much prefer Endomondo for the sharing/community/challenge features.
Dan B
Disengaged member
There's also Runkeeper (the Pro version is free until the end of the month), but I don't think it autopauses so doesn't actually meet the requirement
benb
Epsom
If you end up going for Endomondo, don't forget to join the CC Team.
In fact, even if you prefer a different app, you could still join Endomondo and import your data from the gpx file.
CharlesF
CharlesF
Glasgow
Taken some time to find out how to connect to the Android Market. So far I have downloaded SportyPal and CardioTrainer. SportyPal didn't suit me, so now I'm trying CardioTrainer. I also have to forget Sports Tracker as that had a lot of customisation available.
After posting this, I will download Endomondo and My Tracks; and try them
