Replacement cassette for Cube LTD Pro 2010
bashdem
Hi
I need a replacement cassette for my Cube LTD Pro (2010). The specs suggest the current cassette is a "Shimano HG50 11-32".
Can anyone recommend a suitable replacement? I've already come across 2 HG50's (14.99 and 15.99 on crc/wiggle) but can't identify the difference.
Can any experts point me in the right direction?
Cheers
Deleted member 23692
No idea what Wiggle are playing at, but their website gets worse by the day.
This will do you if you're wanting to swap like for like (assuming you've a 9sp) - http://www.chainreactioncycles.com/Models.aspx?ModelID=443. Back in 2010 this was the part of the Deore range.
Cubist
Still wavin'
Ovver 'thill
Check Woolly Hatshop... they generally have some bargains in, as do Planet X and On One occasionally. Also don't forget that SRAM 9 speed cassettes are compatible, and so if you can find them at dead right money your choices are opened up. (as an example On One had some PG 990s in for less than 40 quid a month or so back.... you just need to Google for the bargains. SRAM denominators for 9 speed are PG 950, 970, 980, 990 for searching purposes.
Shimano in ascending order of quality/price, decreasing weight are Hg50 (Alivio), HG 61 (Deore), HG 80 (SLX) M770 (XT), M980 (XTR)
